Airfilter for S50
Mitch41
Airfilter for S50
Bericht door Mitch41 »
Hi friends,
my name is Gabriel Honnert, 45 years old from Luxembourg, I ride and collect small Honda's since the age of 16. Usually I contribute to english forums but I have a question concerning my SS50Z K1 from 1971.
The carburator side of the intake silencer get's hard as a rock of time, due to the exposure to fuel, I suppose.
Is there a way to soften it again? Heat? Chemicals?
Or is there another popular solution with a bend tube and a K&N filter attached to it?
I wanth to keep the original appaerance with the filter inside the frame.
Sorry to write in english but I do not master the netherland's. I use the google translator.
English,german, french and luxemburgish is no problem.
Greeteings from Luxembourg, Gab aka Mitch41
Saik0
Re: Airfilter for S50
Bericht door Saik0 »
The easiest way is to steal your wife's hairdryer to heat it a little, then it should come off easily.
Other SS50 owners sometimes use a bend tube with a "powerfilter", also have heard of people using old dustcovers for the front springs to connect the powerfilter.
Mitch41 schreef:Hi friends,
Laatst gewijzigd door Saik0 op 02 feb 2010 13:10, 1 keer totaal gewijzigd.
roow
Bericht door roow »
Maybe you can put it into hot water (almost boiled)
http://www.loefbromfietsen.nl/system-lo ... r+and+ss50
Or buy a new one (Ebay, webshops)
Saik0
Depends on if the airfilter is mounted on the bike or not ;) would be fun boiling your honda SS50 completely. LOL
roow
Bericht door roow »
:lol:
niek is ik
Bericht door niek is ik »
roow schreef:Maybe you can put it into hot water (almost boiled)
The one you can still buy today isn't original from a ss50. But from a new honda Benly(cd/cl50)
It fits on your SS50, and is the best alternative, when you want to have a new filter piece.
(i'm sorry for my bad englisch, i suppose :mrgreen: )
mirjam
Bericht door mirjam »
Wynn's car oil substitute has a solution to mix in engine oil to make the oil seals to soften. You can use this to soak de intake and it will soften.
Regards
Bezit: ss50z
S90 RSC
Bericht door CB-viguur »
The new benly filters don't really fit, I took it out again when I tried to mount my carb to it.
The Benly has its carb in a much more horizontal position than the SS50
SS50 carb \| benly airfilter
doesn't fit nicely
Kippenverver
Bezit: Honda ST50-G
Honda CB77 Superhawk
Bericht door Kippenverver »
You could just use a cheap-ass powerfilter with a long tube.. Then it fits snugly in your frame, i use this too because the original filter takes up too much space.
Works beautifully in all conditions.
Ga heen en vereenvoudig u!
Kippenverver
Bezit: Honda ST50-G
For a large battery, wiring, cdi unit and because i don't like the damn thing.
Lejon
Honda CD50H "Lola" - Geruild
Honda st50g "72 - Verkocht
Jincheng J1 "98 - Nu in bezit
Bericht door Lejon »
I've got an cheap-ass filter too. It used to be a Vespa powerfilter with long tube. But it fits perfectly in the frame. The only disadventage is that it makes a loud slurping sound.
Good Luck , Lejon.
Kippenverver schreef:You could just use a cheap-ass powerfilter with a long tube.. Then it fits snugly in your frame, i use this too because the original filter takes up too much space.
Don't use a power filter. You don't want to be a chicken painter.
