elektrsch blok voor Honda
Re: elektrsch blok voor Honda
De vraag rijst dan wel, waar wil jij je linkervoet kwijt.
Leuk voor een bakbrommer.
ps. beetje domme constructie, ze hadden die electromotor een heel stuk naar rechts kunnen schuiven, kettinkje naar de uitgaande as en klaar. Er zit nu een voor een groot deel lucht in die carters.
ps2. wat een lomp blok voor 1kW
buyee schreef: This is a horizontal electric conversion kit that can be installed on Honda's horizontal engine.
It's hard to find an e-bike, so why not start your electric life with this horizontal type as a transition until it comes out?
Motor 48v1000w 4 speed rotary mission
The first photo is the product, and the battery is not included, but all other items are included.
The 6th, 7th, and 8th photos show it installed.
Even with four 12v batteries connected in series for a Cub, he was able to move for the time being.
I use a lithium-ion battery that comes up when you search for "Hinecha battery".
The current maximum speed is 33km/h.
10 inch rear wheel
Sprocket F17R29
Battery 48v8.8Ah
It's slow so I can't ride it around town, but I can have fun with it when it's off the road.
In 4th gear, I climb the 8th hill from a standstill with a weight of 85 kg.
If possible, it would be nice to have a setting that would climb in 1st gear and stop in 4th gear, but I don't know.
I have high hopes for the horizontal engines.
I've created a horizontal electrical bulletin board, so why not share your knowledge with everyone?
https://rara.jp/onewaymotors/
I also wrote about the wiring on the bulletin board.
If you have any other questions, please feel free to ask on the bulletin board and I will answer to the best of my knowledge.
You can also sell directly on the message board.
Please note that some items may have scratches during import.
Sorry for this.
In particular, the sticker on the controller is probably peeled off from the beginning.
Each one sent from China is inspected by connecting the power to the motor to see if it starts.
Shipping is Yamato cash on delivery 140 size. The size is 120, but the weight is 140.
We will also increase peripheral parts such as change pedals and footpegs.
Stay tuned, request OK
There's no kick to start, he has no exhaust note, and won't start unless you charge it.
new sensation
With this, you can make use of your existing vehicle body.
How about your first electric life?
(Added October 28, 2023 15:53)
Maximum speed 37km/h
Wheel F12 R10
Sprocket F18 R29
Connecting the high speed cable to the negative
The rotation speed will increase.
A 17-inch Cub should be able to do more than 50km/h.
More details on the bulletin board
(Added on October 29, 2023, 1:15 p.m.)
Maximum speed 39km/h
updated to
(Added on October 30, 2023, 20:17)
Updated to 43km/h
For more information
Zo te lezen en te zien zit er een versnellingsbak in die carters. Een vierbak. Met een maximum snelheid van 33 lijkt mij dat een beetje zinloos eigenlijk.
- Bezit: Vaillante;
ik zie het ook niet direct in een andere brom gestopt ook. Waar steek je die controlebox weg in bv een Dax? Om dan nog een batterij van x-grootte mee te sleuren. In een Monkey? mss als je de tank leeg maakt en daaronder iets weg kunt werken. Maar dan nog ziet het er niet uit.
nu, ook nutteloos om zoiets te willen maken voor retrofit op een minibike.
NSU Prima D '57 2T scooter.
Piaggio Boxer1.'72(as found)
Met de 17" bijv. Cub is 50km/u haalbaar staat er.
Logisch best wel, de laatste Honda C50 in NL geleverd liep ook max 45 met zijn begrensde 1.6 pk.
Versn.bak met een elektra motor indd zinloos, die levert al direct zn volle koppel vanaf nul toeren.
48v 1000w motor
Met een 20A (960w) accu zou je als je een beetje aan het gas (klopt “gas” wel bij elektrisch?) hangt een uurtje kunnen rondtuffen op een acculading.
Is niet helemaal waar. Ik heb ooit op een Brammo Empulse R gereden, een elektische motor met versnellingsbak. Er zat zelfs een koppeling op, maar die was niet nodig om weg te rijden, alleen voor het schakelen op snelheid. Het gebruik van de versnellingsbak is wel heel anders. Je kan hem bijvoorbeeld in de 3 zetten en daar de hele dag in laten staan. Je merkte wel dat de gekozen versnelling verschil maakt in acceleratie. En in een lage versnelling zit je natuurlijk veel eerder aan het maximale toerental.
Toch bleef het vooral een gimmick om de brandstofverslaafde motorrijder het schakelen te bieden. De 5 of 6 bak die er in zat was ook totaal onnodig.
En dit heb je natuurlijk ook nog, gewoon in Nederland: https://www.dc-bikes.nl/Elektrische-omb ... er-17-inch
Is toch 4taktwinkel? En indd ook maar 1,5 Kw. Dus als std. brommer.
Is wel goed natuurlijk die 1,5Kw anders zijn accu's niet aan te slepen of niet
te betalen indien je zwaardere neemt.
Maar de prijs...dit wordt toch niet verkocht zo?
Dat is waarschijnlijk de bedoeling. want wij(én waarsch.4tw ook)willen natuurlijk benzine verbranden.
- gonzo
Ik snap die hele ophef niet overuitstoot e.d.
Benzine en diesel komt uit...... olie. En hoe ontstaat olie? Juist, plantjes en diertjes, dus hoe biologisch wil je rijden. Is gewoon het toppunt van recyclen...
- Bezit: Vaillante;
mooie uitleg
beetje zoals waarom ik vlees eet: ik spaar die arme platen voor de veganisten
